I need help
Sep 20th, 2008
Hi folks,
I want to use SNMP to create, modify and delete access control lists (ACLs) on a 2621 router. I searched if there is a MIB to use for this purpose and I did not find. Could you provide me with a MIB name that can be used or direct me to another solution to create and delete ACLs dynmaically. I found only one MIB which is used in Signaling System 7 SS7 but it is not beneficial. I don't to use tftp and send the conf file using SNMP. rather than that, I wanna use SNMPset directly.
Im waiting to your replies.
Thanks in advance,
