09-20-2008 01:20 PM - edited 03-14-2019 02:55 AM
I need to enable Dbworker on our ICM 7.2 SR 4 which was recently upgraded from ICM 7.0 SR4. Does this mean that i will need to uninstall the patches and re-run the setup to enable Database Routing and then re-install ICM 7.2 SR4 again?
I would appreciate a quick response on the above.
Mohsin kazi
Solved! Go to Solution.
09-21-2008 08:25 AM
I understand your concern - running 7.0 setup and "adding" a component after ICM has been patched. But you would not do this from the CD - you would run ICMSetup.exe from the C:\icm\bin directory, edit the Call Router and check DB Lookup.
Do you have a lab system to check this in before applying it to production. If not, why not? ;-)
Geoff
09-20-2008 02:20 PM
09-20-2008 06:36 PM
Can i run the ICM 7.0 Setup and edit the router config to enable dbworker, with ICM 7.2 SR 4 installed
09-21-2008 08:25 AM
Geoff
