Remote - Access VPN - Help Urgent
Sep 20th, 2008
My remote-access vpn is messed-up & doesnt work...
current config on ASA as..
tunnel-group RVPNtun type ipsec-ra
tunnel-group RVPNtun general-attributes
address-pool sslpool
authentication-server-group RADIUS
tunnel-group RVPNtun ipsec-attributes
pre-shared-key *
radius-sdi-xauth
crypto isakmp policy 65535
authentication pre-share
encryption 3des
hash sha
group 1
lifetime 86400
crypto ipsec transform-set RVPN esp-3des esp-md5-hmac
ip local pool sslpool 192.168.10.1-192.168.10.40 mask 255.255.255.128
Is something missing???
I tested with CISCO VPN Client version 4 & 5 but no luck.
ASA can ping the ACS 4.0 box and vice-versa...
same account on ACS is used to authenticated ssh session for ASA without any problems
Marwan ALshawi Sun, 09/21/2008 - 01:34
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
can u post the whole config please
Amin Shaikh Mon, 09/22/2008 - 09:10
Is there a way to retrieve group password define on ASA in Remote-Access VPN config ( it appears in * )
singhsaju Mon, 09/22/2008 - 11:25
  • Silver, 250 points or more
try copying the config to tftp server and then read.
Amin Shaikh Tue, 09/23/2008 - 03:57
Remote-Access using ACS 4.0 is working Great.
How would I restrict a group on ACS to be authenticated only for VPN
