Self Signed Certificate for CCA (NAC) CAM
Peter Yardley
I recently upgraded my CCA servers to 4.1.6 and it wants me to replace the temporary cert on the CAM. I have replaced it with a cert I have signed with my CA and uploaded my CA Cert into the CAM and the CAS.
The CAM is happy, and my web browser will verify the cert, however I can't get communication with between the CAM and CAS to work. Anyone had any luck with this?
cleidh_mor
Hi Peter,
Are your CAS certs signed by the CA too? Is there anything in the CAM log about certificate errors?
Cheers,
Yes I had loaded my CA cert into NAC as a CA Authority but I found another problem, to do with upgrading to 4.1.6, which is probably giving me grief and I'm waiting for the TAC to solve that one before I try again.
Did you find the solution for it.
I am also looking for it it is really a pain to first produce Certificates from any CA server then do this.
Got my cert to work after fixing my other problem.
The other problem was a single space after -----End Certificate-----
in the cert I bought for the CAS.
My formulae for creating a self signed cert was
# Create a private key and certificate request # for your own CA:
openssl req -new -newkey rsa:2048 -out ca.csr -keyout ca.key
# Create your CA's self-signed certificate
# Set the days to 3650 so it will last 10 years
openssl x509 -trustout -signkey ca.key -days 3650 -req -in ca.csr -out ca.pem
#edit ca.pem so that the strings
#"TRUSTED CERTIFICATE" read "CERTIFICATE"
# Generate a key for the server Cert
openssl genrsa -out server.key 2048
# Generate a cert signing request for the server
openssl req -new -key server.key -out server.csr
# Sign the request using your CA
# ca.srl contains something like 02
openssl x509 -req -in server.csr -CA ca.pem -days 3650 -CAkey ca.key -CAserial ca.srl -out server.pem
You prolly want to edit your openssl.cnf first and fill in some of the defaults.
