conference with 2 outside caller (from PSTN)???
Sep 21st, 2008
I want to conference with outside callers (from PSTN) but when I use Confr feature on my IP Phone (7945), two outside party disconnected. How do I solve this problem? Thank you
Marwan ALshawi Sun, 09/21/2008 - 04:16
the confrence should be intiated from inside and make sure u have enough DSP confrence resources assigned to the device pool through MGRL
if u use adhoc or meetme
huydien3384 Sun, 09/21/2008 - 18:34
I'm using CUCM 6.1
My Router gateway is 3825 with 1 E1 card, PVDM-64. How do I allocated DSP for conference?
I tried to configure hardware conference bridge on CUCM, and configure conference bridge in the router as follow:
sccp ccm identifier 1 version 5.0.1
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 2 register CFB_12345
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
But the conference bridge did not register with CUCM :( I dont know if I did any thing wrong? Plz help
Marwan ALshawi Sun, 09/21/2008 - 21:59
Prior to actual media resource configuration, the DSPs need to be enabled for DSP farm usage.
The dps services dspfarm command allocates the DSPs to the DSP farm, and the dspfarm
command enables the farm
for example
voice-card 0
dsp services dspfarm
sccp local GigabitEthernet0/1
priority 1 version 5.0.1
sccp (this enable sccp prosses)
sccp ccm group 1
associate profile 1 register CFB_12345
on CCM creat a conf brig (hardware ) and the name should look like (CFB_12345) exactly the same should be in the router and cucm
good luck
huydien3384 Sun, 09/21/2008 - 22:15
thank you very much, now the conference bridge registered with CCM. But the conference still not success.
I notified the command
GW_E1(config)#dsp confbridge maximum sessions ?
<0-0> Specify the maximum conferencing sessions value
Is it mean there is no DSP resource available to conference?
Plz help
Marwan ALshawi Sun, 09/21/2008 - 22:19
u mean after u put the commands i sent u registered ??
can u send me the following show command
show diag
show voice dsp
basicly i guess u lak to dsp resource
huydien3384 Sun, 09/21/2008 - 22:43
I put the command "sccp" and it registered.
Here is the output of show diag:
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8541-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC12351QYM
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-64
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
Show voice dsp: (attached)
Thanks million
