CatOS, how to remove a command from the config?!
Answered Question
Sep 21st, 2008
In CatOS is there anything like the "no" in the IOS ?!
I want to remove a few command lines from a Core Switch, like that:
set spantree portcost 6/4 3004
I know that the "no" keyword before the line doesnt work, any thoughts?!
Thanks!
Caue Wailemann
http://cauew.blogspot.com
Correct Answer by Jon Marshall about 8 years 4 months ago
Caue
Try "clear spantree portcost 6/4"
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/command/reference/cl_m_cop.html#wp1198352
The problem with CatOS is with a number of commands it's not possible to clear it out of the config but the above should work in your case.
Jon
Overall Rating: 4.5 (2 ratings)
Giuseppe Larosa Sun, 09/21/2008 - 12:13
Hello Caue,
if 6/4 is a FE 100 Mbps
set spantree portcost 6/4 19
if 6/4 is a GE 1000 Mbps
set spantree portcost 6/4 4
these should be the default STP costs.
Hope to help
Giuseppe
