Warning message
webvpn cifs size limit
Sep 21st, 2008
Is there a size limit with the webvpn cifs function? I have a 2.4g iso file that I am trying to download via webvpn. When i try to download, it completes instantly with 0 size. Other smaller files work. I am running an asa 5505 with 8.0.4.
bwilmoth Fri, 09/26/2008 - 13:32
  • Silver, 250 points or more
There is no specific size limit for accessing the files using webvpn instead the webvpn user should meet user authentication requirements and file properties.
ryancolson Wed, 10/01/2008 - 15:36
it seems that any file over 2gig it does this with. It is not an authentication issue. The user cna log in, and download any file that is less then 2g. If the file is 2g or more, i experiance the issues where it completes instantly at 0 bytes. Also, is there an easy way to download a whole folder w/o having to do each file one at a time
