Router question
willemvwyk
Hello
I am looking at the Cisco 38xx series router with an HWIC 1GE card connection. However I would like to know if this card gives true 1Gig speed over the ethernet or whether the 1Gig throughput will be downgraded due to the card's bus speed?
I have been reading on Cisco's website about this card but nowhere can I find any indication of them showing the true throughput.
Any help will be much appreciated.
Many Thanks
royalblues
Level 10
Level 10
No you wouldn't get true 1Gig throughput
The 38xx platform has a throughput for 179.Mbps (3825) or 356 Mbps (3845). THe statistic however are based on 64 byte packets. The throughput would increase for larger packet sizes but you would not get true 1Gbps
Narayan
Hello Narayan.
Thank you for the help. I forgot to ask, does what you said above also apply to ASA devices and Catalysts?
wvw
Different platforms & devices (routers, firewalls, L3 switches - sups, etc.) are rated differently. Best to verify with each router/platform/chassis/module on all equipment.
Don't have information on hand for ASAs but for Catalyst switches see attachement for their performance.
