Firewall Ports - Silent Monitoring & Recording
My client is using UCCX 5.0 and they would like to have the silent monitoring and recording.
However, on all the Agents & Supervisors
desktop PCs, my client doesn't want to disable their *Windows Firewall* completely. Is there any particular Cisco instructions so that I can selectively allow only *certain ports* to go through??
Kind Regards,
mikram Mon, 09/22/2008 - 05:41
Could you pls also check if LAN Cards support VLAN tagging.
matt.rossmeisl Tue, 09/23/2008 - 13:32
Try allowing ping through. Just came across this in the SRND:
Ping, NAT, PAT, and Reverse DNS Lookups
The following configurations and information are required for the CAD software to work properly.
The Cisco Agent Desktop application uses the TCP Ping command to verify that it can communicate
with the active VoIP servers. This is done even if no agents are configured to use a VoIP Monitor service
for the silent monitoring feature. If Ping is disabled on the machine running a CAD VoIP Monitor Server,
the silent monitoring feature will not work properly.
There are certain CAD modules that rely upon reverse DNS lookups. If this feature is turned off on the
machines running CAD services, there will be a loss of some functionality and errors will be generated
and logged.
Network Address Translation (NAT) is only supported between the Cisco Agent Desktop and the CRS
servers. Port Address Translation (PAT) is not supported.
