UCCX CAD errors
c-pinilla
In the attached files you can find the errors we are getting. Does anybody know why it is happening?
Carlos
7 Replies 7
mikram
Level 4
Level 4
Could you pls repost the files as cant seems to download it.
cheers
bobsairam
Able to download .But language not in English,
Which Locale are you using?
The language is Spanish. It says that the call ID has changed. If an agent try to log out it says that there is an active call and the agent should stay logged in.
Carlos
When and how are you getting these errors?
david
We are getting the errors even if the agent has no active calls.
We are using UCCx 5.0
Carlos
Can somone translate what this says to english? :C)
Chad
I'am translating it again (no comment). It says that the call ID has changed. If an agent tries to log out it says that there is an active call and the agent should stay logged in.
Carlos
