IPCC
Sep 21st, 2008
i have loaded a software on my manager's laptop to receive reports of agents after every two hours, scheduling of the historical reports have been set but the reports are not populating.
secondly i loaded cisco agent supervisor on his laptop but still its not showing, if agents are ready, not ready, busy or what, it only gives an error message. thanks.
bobsairam Thu, 09/25/2008 - 09:45
Check any firwall enabled ,if yes disable first and try again.
What are you getting ?Can you attach the snapshot ,
What verion are you using ?is it IPCCX and IPCC ent ?
HTH *Pls rate it*
stuart.pannell Fri, 09/26/2008 - 03:46
What version of Java are you using, I had similar issues when we upgraded Java to version 1.5?
