"ip verify reverse-path interface" on ASA
Sep 22nd, 2008
I have add the "ip verify reverse-path interface <interface name>" to all my interfaces on my ASA, the syslog alerts I'm getting now are:
Deny UDP reverse path check from 192.168.1.1 to 192.168.2.2 on interface DMZ2
Deny ICMP reverse path check from 192.168.1.1 to 192.168.2.2 on interface DMZ2
What exactly is happening to produce these messages since I turned on that command?
Overall Rating: 5 (1 ratings)
guibarati Mon, 09/22/2008 - 06:19
This command makes the ASA to check the source of the packet comming in an interface. The firewall will see if it has a route for the source of the packed and if the route if through the interface where the packet came from.
That means, if the firewall have a route for 192.168.1.0/24 on interface inside and a packet with source 192.168.1.38 comes in interface DMZ the ASA will block it supposing it's spoofed.
