Allow tracert/pathping through firewall?
Sep 22nd, 2008
I have an ASA 5520, I am using sub-interfaces to a VLAN switch (Cisco 3750). I'm based on the "inside" and I need to use pathping and tracert from my PC to these remote networks that are on the VLANs.
I think the firewall might be blocking this, but am not sure. As soon as my trace gets to the firewall I get the * * * appear as if it's getting blocked.
Any Ideas?
whiteford Mon, 09/22/2008 - 07:31
I just want the DMZ1 servers to tracert to my inside PC, do you know how I can do through the ASDM?
whiteford Mon, 09/22/2008 - 07:44
Thing is I can ping fine, it's just the tracert and pathpings
whiteford Mon, 09/22/2008 - 07:53
policy-map global_policy
class inspection_default
inspect icmp
has been added, is that a NAT I have to add?
