Extranet/ prefixlist
Sep 22nd, 2008
I have to configure extranets.
This has to be done for different routers(or subnets) belonging to 2 different vrf's.
Traffic from A to B has to be allowed and denied from B to A.
Could somebody advise me?
Thank you
singhsaju Mon, 09/22/2008 - 06:50
Hi Fred,
You can consider doing PAT or dynamic NAT from A to B . PAT will hide your network A .So no traffic can be sent to network A from B.
Pls rate helpful posts
Giuseppe Larosa Mon, 09/22/2008 - 08:45
Hello Fred,
you can implement an MPLS VPN extranet solution to make communication possible between the two VRFs.
On each router belonging to VRF A you can accept TCP sessions only if already established
access-list 123 permit tcp x.x.x.x y.y.y.y any established
access-list 123 deny tcp x.x.x.x y.y.y.y any
access-list 123 permit ip any any
int gx/y
ip vrf forwarding VRF_A
ip access-group 123 out
where x.x.x.x represents the networks of VRF B.
the extranet solution is simply the adding of route-target import command within VRF interfaces
ip vrf VRF_A
route-target import
to be added
ip vrf VRF_B
route-target import
Hope to help
