MSE and WCS
Sep 22nd, 2008
Hi ALL
I have two quick questions ,
1. Is the MSE replacing the location appliance or do they work together.
2.I f i need to upgrade my WCS to do location can i just purchase the following part number WCS-LOC-UPG-K9
Thanks in advance
Tau Mailula
Scott Fella Mon, 09/22/2008 - 17:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What I have heard, that it will not. There will be an MSE lite version that might eventually replace the LA. I don't know for sure if that will allow you to or not. Ask your Cisco AE unless someone here can help you with that.
bbxie Mon, 09/22/2008 - 17:50
  • Silver, 250 points or more
1. MSE replace location appliance
2. if you previously have base version WCS, such as WCS-APBASE-500, then you need to purchase WCS-APLOC-UPG-500 to upgrade it to support 500 AP with location feature
ctermini Tue, 09/23/2008 - 04:18
  • Cisco Employee,
Hi Tau,
The MSE supports all the capabilities and programmatic interfaces of the Location Appliance plus the ability to run other Cisco or third party developed applications. Think of it as the next generation Location Appliance and as such will replace it in time.
A solution will comprise of the Location Appliance or the MSE, the Location Appliance is not required in addition to the MSE.
Dependant upon the version and current licensing of your WCS that is the right upgrade. Best bet is to check the WCS Licensing and Upgrade guide which discusses the various options at:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/product_data_sheet0900aecd804b4646.html
rgds
Carlo
Scott Fella Tue, 09/23/2008 - 07:46
  • Hall of Fame,
    2017 Wireless
Cisco has not officially said that the MSE will replace the LA. When the smaller version of the MSE comes out, then that mightl replace the LA....
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
