Disable My Phone Apps in CCME
Sep 22nd, 2008
Hi, I am implementing CCME 4.3 and I would like to disable the following to appear when services key is pressed: My Phone Apps. Is there any way to do this? I configured no phone-ui speeddial-fast dial under ephone but I am still getting My Phone Apps.
Chandrasen
irisrios Fri, 09/26/2008 - 12:05
  • Silver, 250 points or more
The command “no phone-ui speeddial-fastdial” is for disabling the user interface for speed-dial and fast-dial configuration.
ephone phone-tag
cg100668 Fri, 09/26/2008 - 12:47
Hi, thanks for the reply. I am using CCME 4.3 and I have already tried the command but no luck. Should I check anything else? Please advise.
Chandrasen
bbuck2002 Wed, 05/13/2009 - 15:39
Has anyone found an answer to this issue? I am using CCME 7.0 and am experiencing the same issue. I have implemented the "no phone-ui" commands, yet the options appearing in the service menu still exist: "Extension Mobility" and "My Phone Apps". Is there no way to disable these?
Paolo Bevilacqua Wed, 05/13/2009 - 16:48
  • Hall of Fame,
    Founding Member
May be some of the TAC guys here can quickly verify this and file a bug as necessary.
