Set BLFSpeedDials with Partition using AXL
Sep 22nd, 2008
Hi all,
I'm trying to write a little application that configures BLF-Speeddials on CCM6.1.
It's working, but there seems to be no way to include the Partition information into the request. If a DN is present in more than one Partition, there seem to be no way to choose the right one.
Is there a way I don't know about?
Thanks in advance
Jörg
stephan.steiner Tue, 09/23/2008 - 07:12
  • Silver, 250 points or more
While I don't recall what's in the field (I think it's the DN's uuid), the blfDirn references a directory number whereas the blfDest just gives a directory number string.. so with the latter you are correct (and it's the same in ccmadmin).. there's no way to specify a partition.. however, in ccmadmin if you use the directory number, you get to chose between different DNs that have the same number but are in different partitions.. so you can use the same element in AXL for the same result.
