LMS 3.1 and SSL 443/tcp port change under Solaris 10
Answered Question
Sep 22nd, 2008
LMS 3.1 has been installed with default ports # for http (1741) and 443 for SSL https.
Is there an easy way to replace 443 port by another port for security reason ?
Thanks in advance for your help.
Correct Answer by Joe Clarke about 8 years 6 months ago
Sure. You can run the NMSROOT/MDC/Apache/bin/changeport command to change the HTTP and HTTPS ports used.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 09/22/2008 - 08:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
