SUP720 Redundancy Configuration Help Please
brobertson
We want to config 2 6506-E Sup720 MSFC3 with redudant supervisors in the event one fails. I have read the documents regarding SSO but still am not sure how to configure. I have configured both sups with the same configuration and trunked via ethernet cable from the supervisor uplink port. When I do a sh redundancy states command i receive the following
my state = 13 -ACTIVE
peer state = 1 -DISABLED
Mode = Simplex
Unit = Primary
Unit ID = 5
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured) = sso
Redundancy State = Non Redundant
Maintenance Mode = Disabled
Communications = Down Reason: Simplex mode
Any help/guidance would be much apprecitaed. Learning as I go working on these LAN switches.
Brian,
What you are trying to cannot be done with the equipment you currently have. SSO redundancy is for supervisor redundancy within the same chassis. There is VSS that will do what you want as shown in the diagram. Here's a link for that.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_white_paper0900aecd806ee2ed.html
HTH,
Mark
Mark Yeates
Level 7
Level 7
What commands are you using for SSO? There is no need to have a patch cable between the supervisors for SSO redundancy. Below is a working example of how to configure SSO. Copy this into the primary supervisor and it will reload the second and SSO should work.
redundancy
mode sso
main-cpu
auto-sync standard
HTH,
Mark
Thanks for the reply Mark, I will have to apologize for my earlier description. We have 2 seperate chassis with one SUP720(3) in each. We are planning on running redundant links from the servers and access switches to each chassis. Currently there is a single GE connection from the RJ45 connection on each supervisor. I am trying to determine the best way to link the supervisors in an active/standby configuration.
Brian,
HTH,
Mark
Thanks again for the info Mark. I will find another method of getting the supervisors to work in a redundant configuration.
