Network Latency Tools
Sep 22nd, 2008
Does anyone know a good tool to monitor Network latency and errors.
Thanks S
Sai
Overall Rating: 4 (1 ratings)
using normal ping, you may not be ablt to trace any CRC on interface causing the errors and making the node not respong to the ping requests.
Then, using normal ping you would not have any idea exactly WHEN any of your nodes stopped responding to ping request and WHEN it came back to normal. In other words, you will not be able to anylze the historical events.
