7600 with ES-20 for an BGP peering Internet GW
Sep 22nd, 2008
We are planning to use a 7606S with RSP720-3CXL as an internet gateway router which would be peering with at least 3 other ISPs. Here is my port requirement.
at least 6 1000Base-T ports
at least 6 100Base-T ports
at least 6 1000Base-SX (fiber SFP) ports
I've looked at the line card options, and thought that ES-20 (7600-ES20-GE3CXL) would do the job ideally.
What do you think ?
Also there is a license associated for that card for IPv6/MVPN/Layer 3 IP/MPLS VPN.
If I do not buy that, can I proceed with my planned setup ?
Many thanks for any help that you can provide.
PS: I posted this in the MPLS section only cause I thought guys doing MPLS would be very familiar with my problem.
Reza Sharifi Mon, 09/22/2008 - 09:09
Are you planning to put all of your connections into 1 blade in one router?
Since you are connecting to 3 different service providers, I would put each service provider in a different line card.
And a better solution would be to split the connections between multiple routes (if funding available)
Just my 0.2 cents
Reza
thedinuka Mon, 09/22/2008 - 09:15
funding would be the major issue here. If available , surely I would put each SP in a different line card, But in that case, I wouldn't buy the ES-20 cards as that would be a waste. I would rather buy SIP/SPAs.
in any case thanks for your input. You wouldn't have any idea on the ES-20 suitability for this and the license issue would you ?
BR
jon.harald.bovr... Tue, 09/23/2008 - 10:46
I would rather go for two 760x with
RSP-720-10GE with WS-X6724-SFP
interconnect between switches 10Gbit
Not verified but assume these two routers to be less expensive than one router with ES20 -GE3CXL
I would not use ES20 due to high cost related to 3CXL.
Jon
thedinuka Tue, 09/23/2008 - 18:23
But the WS-67xx cards are of LAN type right? they do not fit in an environment where you would be connecting to ISP s through those.
armin.kask@mail.ee Tue, 09/23/2008 - 22:03
Why not?
They can be used as routed ports. The only difference with ES-20 is that with them you cannot do VPLS and some advanced QoS things.
jon.harald.bovr... Tue, 09/23/2008 - 22:12
Correct.
Our company have been using two 7604/sup720-3BXL/WS-X6704-10GE as peering router for several years.
Connected to transit (1G), Private peerings (1G) and national IX (1G). total 60-80 peers on each router.
You don't ned MPLS, VPLS or advanced QoS on a peering router.
Unless your intention are Multicast MSDP or MPLS Option 10a-b-c peerings.
Get a qoute og ES20 with MPLS licence - believe its about US$80.000
Jon
