Ether channel configuration issue
Sep 22nd, 2008
Hello all
I am finding a strange config issue in my cisco WS-C6513 switch while i try to create a L2 etherchannel with my production server.The IOS version is (c6sup2_rp-JK2O3SV-M), Version 12.1(27b)E4 .
the config coomands i tried for the ether channel is as follows .I can see that the Po30 is auto matically negotiated to dot1q trunk, which i didnt really configured.
Router#sh ether sum | in Po30
30 Po30(SU) - Gi11/36(P) Gi11/37(P)
Router#sh run int gi11/36
Building configuration...
Current configuration : 128 bytes
interface GigabitEthernet11/36
switchport
switchport access vlan 139
switchport mode access
channel-group 30 mode on
end
Router#sh run int gi11/37
interface GigabitEthernet11/37
switchport
end
Router#sh run int po30
Current configuration : 173 bytes
interface Port-channel30
description PortChannel-30 to DSSACS1
switchport
end
My doubt is , is this normal ? or is this an issue? I dont need the dot1q encapsulaion that is coming automatically.Kindly advice.
Kind regards
Ullas
dhopper82 Mon, 09/22/2008 - 09:42
The only thing I can think of is that at Po30 existed before. It looks like it was used for something that was trunked. The encapsulation type will not go away even after you change the port to access.
ullasupendran Mon, 09/22/2008 - 09:46
hi
I was also thinking the same and i configured a new channel .Still the problem exists.Is this a IOS bug or something?
Ullas
dhopper82 Mon, 09/22/2008 - 10:17
You got me on that one. We're running 12.2 and have not had any issues like this. Our physical interfaces are set to desirable instead of on. That's the only difference as far as configuration.
glen.grant Mon, 09/22/2008 - 11:09
  • Purple, 4500 points or more
I think the command is just there , don't think it can actually be trunking if the channel is switchport mode access, really just cosmetic . Verify with a "show int trunk" command and see if the port channel is actually trunking or not , don't think it can be if its a
access port.
ullasupendran Mon, 09/22/2008 - 12:38
I verified it .the port channel is not trunking. I have some reachability issues with the server connected to this port channel. So i was curious abt ths trunk command.I have another cat6513 swith with an IOS Version 12.1(22)E2 which dont have this issue at all.This problem is found in an IOS Version 12.1(27b)E4 which is a latest release.Do you guys think is this an added feature in this version or A BUG?
