interface Broadcasts on serial link
Answered Question
Sep 22nd, 2008
Hi all,
i see slowness in network.
see packet drops.
check the serial link
Serial0/0/0 is up, line protocol is up
Hardware is GT96K Serial
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 73/255, rxload 48/255
Encapsulation FRAME-RELAY IETF, loopback not set
Keepalive set (10 sec)
LMI enq sent 1007, LMI stat recvd 1007, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
FR SVC disabled, LAPF state down
Broadcast queue 0/64, broadcasts sent/dropped 2355/0, interface broadcasts 2188
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 02:47:55
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/86/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
5 minute input rate 295000 bits/sec, 56 packets/sec
5 minute output rate 444000 bits/sec, 64 packets/sec
618921 packets input, 471611347 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 1 giants, 0 throttles
151 input errors, 151 CRC, 128 frame, 107 overrun, 0 ignored, 82 abort
723009 packets output, 525070248 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Serial0/0/0.1 is up, line protocol is up
Internet address is 161.245.75.220/24
i clear the counters.
can some one explain me about
many thanks
Correct Answer by Richard Burts about 8 years 4 months ago
mahesh
Let me try to explain it this way:
- EIGRP sends multicast packets for hello messages and for update messages.
- when you have a network statement under EIGRP that matches a serial interface then EIGRP begins to send hello messages and update messages over the serial interface.
- so you are sending and receiving multicast packets on the serial/frame relay interfaces.
- I believe that the multicast EIGRP packets are being counted in the interface broadcast counter.
Perhaps the name they give the counter is not as specific as it should be. I believe that it counts more than just "broadcast" packets. We frequently treat multicast and broadcast as if they are different things, but in some sense broadcast is a special case of multicast.
Rick
Overall Rating: 5 (2 ratings)
mahesh18 Mon, 09/22/2008 - 11:05
Here u go
#sh ip protocols
Routing Protocol is "eigrp 305"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Redistributing: eigrp 305
EIGRP NSF-aware route hold timer is 240s
Automatic network summarization is not in effect
Maximum path: 4
Routing for Networks:
161.245.0.0
172.23.0.0
172.24.0.0
Routing Information Sources:
Gateway Distance Last Update
161.245.75.221 90 00:21:57
Distance: internal 90 external 170
thanks
Mahesh
John Blakley Mon, 09/22/2008 - 11:15
is the 161.245.0.0 a public subnet? Can you post your interface configs and eigrp config?
--John
mahesh18 Mon, 09/22/2008 - 11:22
urrent configuration : 11009 bytes
! Last configuration change at 09:56:23 MDT Tue Sep 16 2008 by istardc
! NVRAM config last updated at 14:45:18 MDT Tue Sep 16 2008 by istardc
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service linenumber
hostname idpodr1
boot-start-marker
boot-end-marker
logging buffered 4097 debugging
logging console warnings
enable secret 5 $1$IiqQ$ncRPJmMtBCZTLq6gcxDW/0
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login noaaa none
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
resource policy
clock timezone MST -7
clock summer-time MDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
no ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
ip name-server 161.245.25.60
ip name-server 172.31.99.20
ip name-server 192.168.6.100
Ccrypto pki trustpoint TP-self-signed-280346003
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-280346003
revocation-check none
rsakeypair TP-self-signed-280346003
crypto pki certificate chain TP-self-signed-280346003
certificate self-signed 01
3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32383033 34363030 33301E17 0D303531 31303932 30303531
305A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3238 30333436
30303330 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
9790CDA9 8FB264AE C4515AD8 8D415F1E C45F0AF2 BA355EC4 588F4A90 86EBB7E6
4810278C 48A8E9AD E29FA2CD 688F5F66 C0A95F7F 45AAC3AA 9E3DCB9B F5510505
E30E2D29 EBB10D16 6D07FFA4 F08829D6 1BF752E9 232D4D4E B0629AEC D3864057
85395AB7 F829BA1D 18AFA6DA 2B9AAE86 2442844B D95494CA CB4A3511 C2A447BD
02030100 01A37730 75300F06 03551D13 0101FF04 05300301 01FF3022 0603551D
11041B30 19821779 6F75726E 616D652E 796F7572 646F6D61 696E2E63 6F6D301F
0603551D 23041830 168014DD E6BBD6FA 54A6574C 39E34ACC 7ED23387 78881930
1D060355 1D0E0416 0414DDE6 BBD6FA54 A6574C39 E34ACC7E D2338778 8819300D
06092A86 4886F70D 01010405 00038181 0047DBC3 F3995B95 B82BE989 7B524C31
787CCDA8 BE665E38 B4653AC7 3DDBDDC3 FE56270D 568D674C 09EDB369 71985AEA
C986F1C5 9005E53A 400191BC 103FE054 02653D8C FD7E5FB7 A3DE7A2A 7616CC59
BCDD1769 80A02B34 582429AC F430EF1B 233D496D 202F2096 D71CD71B C4B06A75
B3F5B15A 239CA766 C07670D5 D2B2767F AF
quit
interface Loopback0
ip address 161.245.9.88 255.255.255.255
interface GigabitEthernet0/0
description - SCADA LAN
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description - Business LAN
ip address 161.245.76.220 255.255.255.128
ip helper-address 161.245.25.60
ip helper-address 192.168.250.10
ip helper-address 172.31.99.20
no ip unreachables
duplex auto
speed auto
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
interface Serial0/0/0.1 point-to-point
ip address 161.245.75.220 255.255.255.0
frame-relay interface-dlci 114 IETF
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
mahesh18 Mon, 09/22/2008 - 11:24
router eigrp 305
network 161.245.0.0
network 172.23.0.0
network 172.24.0.0
no auto-summary
no eigrp log-neighbor-changes
ip default-gateway 161.245.75.221
ip classless
ip route 0.0.0.0 0.0.0.0 161.245.9.1
ip route 0.0.0.0 0.0.0.0 161.245.9.2 4
ip route 161.245.0.0 255.255.0.0 0.0.0.0
no ip http server
no ip http secure-server
ip tacacs source-interface Loopback0
^C
line con 0
password 7 123E5547165F1945
line aux 0
exec-timeout 9 0
password 7 071B24415E
modem Dialin
transport input all
stopbits 1
line vty 0 4
access-class 100 in
privilege level 15
password 7 0477580B022842494D
transport input ssh
line vty 5 9
access-class 100 in
privilege level 15
password 7 072372414300170253
transport input ssh
line vty 10 15
access-class 100 in
privilege level 15
password 7 153E5801092325236C
transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17180303
ntp server 192.168.9.1
ntp server 192.168.9.2
end
John Blakley Mon, 09/22/2008 - 11:52
The only thing that jumps out at me, and perhaps others can help, is that you're ip helper address is pointing to somewhere outside of your LAN. That would send broadcasts out since that's how DHCP works. When your workstations come up and traffic is sent to that VLAN, they're being directed to these addresses. By chance, are the 192 or the 172.31 addresses on the other side of your point-to-point?
John
pls rate if helpful :-)
mahesh18 Mon, 09/22/2008 - 12:31
thanks for reply yes ip 192 and 168 are on other side of point to point link
Richard Burts Mon, 09/22/2008 - 12:56
mahesh
John has slightly confused the operation of DHCP and helper addresses. He is correct that the original request from the client is a broadcast. But that is received on the LAN interface. The router does not forward the broadcast request to the DHCP server but uses the address specified in the helper-address command to send a unicast packet to the server.
I believe that there is another explanation for what you are seeing. Even though it is labled as interface broadcasts I believe that it counts multicast in that category also. And since you are running EIGRP on the interface I believe that you are receiving EIGRP multicast hello packets that that is what is being counted in the interface broadcast counter.
Rick
mahesh18 Tue, 09/23/2008 - 06:25
Hi Rick,
Can u explain me in more detail interface broadcasts on serial link.
i do not understand this part
thanks
Correct Answer
Richard Burts Tue, 09/23/2008 - 07:23
mahesh
Rick
