09-22-2008 10:40 AM - edited 03-15-2019 01:27 PM
After change the dc directory password.
i m not able to forword call from IPT softkey. but i can using ccm web application. i restared all the services in ccm publisher and subscribers but still now i m facing the prob.
So please help me.
09-22-2008 11:08 AM
DC has nothing to do with CFA (CFA is related to CUCM DB), use dblhelper to check status and if necessary republish
java
if this helps, please rate
09-22-2008 11:12 AM
Thanks for your reply.
I think also its BD sync related prob but i have no dblhelper. without BDLhelper is it possible to resync.
09-22-2008 11:13 AM
that would require you to go to each and every single server and restart the snapshot agent and pull subscription, look for dblhelper at netpro and download it
java
09-22-2008 11:19 AM
please give me the exact procedure. How can i restart the snapshot agent and pull subscription.Its a ipcc. All IPT are connected with this ccm cluster.So is it possible to make resync with out down time.
