SDM on router 837
Sep 22nd, 2008
When trying to install SDM on my 837 router it prompts me for a user name and password as well as a hostname or IP address, how do I assign these to the router? is it just a matter of
comfig t
router# hostname XXX
Istvan_Rabai Tue, 09/23/2008 - 10:05
Hi Shane,
Assign an ip address on the router interface through which you connect to the router with SDM:
example:
conf t
interface FastEthernet0/0
ip address 10.1.1.1 255.255.255.0
Then create a username and password as follows:
conf t
username xxxxx privilege 15 password yyyyy
then enable http server:
ip http server
When SDM prompts you for the ip address, username and password, you should then type these in what you have configured into the router.
Cheers:
Istvan
