PEAP doubt
Sep 22nd, 2008
Srs, I have a doubt with PEAP.
In the same text I read that clients do not require certificates, but therefore after I read that certificate authority must be used at the each client. (see file enclosure).
I read several articles on the theme, but I continue not understanding on the certificates.
Somebody Can help me.
bbxie Mon, 09/22/2008 - 17:56
  • Silver, 250 points or more
PEAP require the Radius server must install a server certificate.
For Client, if you check "validate server certificate", then you have to install a client cert on it; if you un-check "validate server certificate", then you don't need to install cert on client.
Scott Fella Mon, 09/22/2008 - 17:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
EAP-TLS requires certificate on the client side also. PEAP only requires a certificate on the radius server.
http://en.wikipedia.org/wiki/Extensible_Authentication_Protocol
Trending Topics - Security & Network
