Cisco 2955S questions
Sep 22nd, 2008
Hello everybody,
I'm trying to connect two 2955S switches using SM fiber, I'm able get the connection up for a couple of hours and then it goes down. Sometimes goes up and down several times during the day; however I'm not able to get a stable connection. The switches are located in buildings that are located less than a mile apart.
Is there a minimal distance for connecting those devices using single mode fiber? If that is the case, what is that distance?
Should I use attenuators? If that is the case how do I calculate the required attenuation?
Thank you for your help
Giuseppe Larosa Fri, 09/26/2008 - 12:34
Hello Armando,
the distance is not a problem and you shouldn't need to use an attenuator.
Are there any log messages that could be related to to the troubled link ?
try to disable the interface keepalive some IOS versions have issues with them that lead to errdisable.
Do you see incrementing errors in the interfaces during the day ?
show interface gi0/x
If available have someone test attenuation with an optical TDR when a loop is made on the other side.
Verify also to use GBICs/SFPs that are of the same vendor because using different can sometimes lead to problems.
Hope to help
