Transfering a call from Unity to a Hunt Pilot.
I have a Call handler setup in Unity that allows caller input (Press 1 for Billing, Press 2 for.....) I have a Hunt Pilot setup in Callmanager that I would like to transfer a call to when the caller presses 1. So far I have not been able to congifure the callhandler to transfer the call to the Hunt Pilot. I have tried entering the Hunt Pilot DN in the transfer to subscriber field but it does not work. Any suggestions?
Monte
Overall Rating: 4 (1 ratings)
Jaime Valencia Mon, 09/22/2008 - 15:13
  • Cisco Employee,
  • Hall of Fame,
    2011
create a dummy call handler and under transfer options set "yes, ring subscriber a this extension", on the call handler where you're going to press 1 configure caller input "attempt transfer to" and choose the dummy call handler
that's a very common and ordinary setup
confirm your transfer rules allow dialing that DN
java
if this helps, please rate
