09-22-2008 03:14 PM - edited 03-18-2019 09:41 PM
When user check the VM she's getting the error message "Your inbox is almost full. If your inbox exceeds its storage limit you will not be able to send or receive new messages. To reduce the size of your inbox delete some messages now. You will be reminded to do so each time you log on until your inbox is no longer close to its storage limit.â
The system admin checked all settings on Exchange server. There is no any inbox limit setup for this user. We deleted the voicemail account from Unity and re-add it back but same problem.
The user is able to get voicemail message on the Outlook but over the Voip phone. We wonder if there is something cached on Unity so user get this message.
Here is what I got from Event View on Unity:
Failed to set message lamp for xxx ext.xxx. reason: load from Doh failed. Turn on Doh diagnostics to trubleshoot.
Any idea or suggestion?
09-22-2008 04:52 PM
What version of Unity? Check out this old thread:
Have deleted items been purged for this user? These also count toward the total size of the mailbox. The following doc shows how you can manage mailbox sizes:
Hope this helps,
Brad
09-22-2008 04:57 PM
Hi Kang,
I would have a look at this thread with nice answers from Jeff and Keith from Cisco;
Hope this helps!
Rob
