Compatible plantronic headsets
Sep 22nd, 2008
It has been some time since we have updated our compatible list of headsets with our cisco phones.
Does anyone have a list of the headsets plantronics manufactures that are good quality (these will be used for our operators).
Currently the only 2 we have are cs55/hl10 and the cs10/hl10
Overall Rating: 5 (1 ratings)
rob.huffman Mon, 09/22/2008 - 16:48
Hi Marcus,
Look in this section for a complete list;
Find My Headset (choose Cisco and IP Phone Model)
You may want to look at a great new method of using Wireless Headsets that Plantronics and Cisco have developed that work with the 7942/7945, 7962/7965 and 7975 IP Phones only so far. The Plantronics HHC adapter enables hookswitch control and ***ring detection for CS50, CS55, CS60, CS70, CS70N, CS351N, CS361N and V510S wireless headsets, eliminating the need for a an HL10 lifter.)
With the use of an Adaptor Part # APC-4 (called the HHC Adaptor) which plugs into the Aux Port on the base of the phone allows calls to be answered and disconnected via the Headset without the use of the Lifter!
You can't believe how well this new setup works :)
HHC adapter (APC-4) Product Information
Hope this helps!
marcuscastellanos Tue, 10/14/2008 - 07:56
Hey Rob,
The first link does not work for me for some reason.
On a side note, we utilize mostly 7940 and 7960 so we cant use the HHC adapter, doh!
