CSS11503 discarding packets
jawschaar
Hi i have a service for port 8002 defined on my css and i'm seeing some soap posts being discarded by the CSS even though they work when they go directly to the back end ip addresses I port spanned the uplink and i can see the packets coming in but nothing getts sent to the backend? what is the css doing is it checking the HTTP header format?
if i encode the posts using a diffrent script they work.
Gilles Dufour
If this is a L3 or L4 rule the CSS doesn't care about the format.
However, if you ask the CSS to match a url, or find a cookie, making the rule L7, then yes the format needs to be correct or the packet is silently dropped.
Gilles.
these are my rules is the MMSC_10021_URL_C1N1 service rule the one that is causing my problem?
service MMSC_2_Port10021
ip address 172.22.75.11
keepalive frequency 10
keepalive maxfailure 5
keepalive retryperiod 2
port 8002
keepalive type script cmg_http_script "172.22.75.11 /keepalive 8002"
active
service MMSC_1_Port10021
ip address 172.22.75.10
port 8002
keepalive type script cmg_http_script "172.22.75.10 /keepalive 8002"
active
owner mmsc.optus.com.au
content CDS_389
add service cds-1-Port389
add service cds-2-Port389
protocol tcp
vip address 172.22.72.245
port 389
active
content MMSC_10021
add service MMSC_1_Port10021
add service MMSC_2_Port10021
vip address 172.22.72.251
port 8002
protocol tcp
active
content MMSC_10021_URL_C1N1
no persistent
primarySorryServer MMSC_2_Port10021
url "/mmsc/1_1"
protocol tcp
port 8002
active
content MMSC_10021_URL_C1N2
no persistent
primarySorryServer MMSC_1_Port10021
url "/mmsc/1_2"
protocol tcp
port 8002
active
group MMSC
add destination service MMSC_1_Port10021
add destination service MMSC_2_Port10021
add destination service MMSC_1_Port25
add destination service MMSC_2_Port25
active
I suspended the 2 rules
and i can now submit
thank you very much.
