Using External Database (windows) for ACS Authentication
Sep 22nd, 2008
Hi !!
Is it recommended to use windows external database for ACS Authentication
Premdeep Banga Tue, 09/23/2008 - 04:09
It completely depends on your requirement. If you already have a user database on Windows AD. Then rebuilding the user database wont make any sence. Its better to use the already maintained database. Given you do not have a special requirement for which you are bound to create a new database.
Please rate if it helps!
