Using E1 card for Voice Communication
Sep 22nd, 2008
Dear All,
Currently we are using E&M cards at our voice router for connectivity with PABX.
PABX (Head Office) --> Router (Head Office) --> Router (Remote) --> PABX (Remote).
Above is the topology which we are using right now. Due to less voice channels, we have bought E1 cards for routers and for PABX both. We have connected E1 cards at both ends. But here is what i am having problems configuring.
Following are the basic configurations that we have done on our router as a test case.
network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
controller E1 0/0/0
clock source internal
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn overlap-receiving
isdn incoming-voice voice
isdn T310 60000
isdn bchan-number-order ascending
no cdp enable
By this configuration i am just trying to get a dial tone which i get untill i assign a dial-peer to it.
dial-peer voice 1000 pots
destination-pattern 8*T
port 0/0/0:15
prefix 8*
The tone just vanishes away after configuring this dial-peer. Any recommendations or suggestions. Alos, any help in configuring this scenario will be great.
Thanks in advance.
-Jay
irisrios Mon, 09/29/2008 - 06:24
  • Silver, 250 points or more
Check to see if the dial-peer pots are configured with the direct-inward-dial command. This command disables dial tone from the voice port. If you remove the direct-inward-dial command from the dial-peer pots, then the digital voice port provides dial tone.
Troubleshooting No Dial Tone Issues:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00800a4795.shtml
