crossover - straight through cable question
peter-net
can someone tell me the command syntax to allow a switch port to "auto sense" or electronically re-orientate pin outs between a crossover and a straight through cable? Thanks, peter@it-123.co.uk
shastymacnasty
"The Auto-MDIX feature is enabled by default on switches running Cisco IOS
Release 12.2(1SE or later. For releases between Cisco IOS Release 12.1
(14)EA1 and 12.2(1SE, the Auto-MDIX feature is disabled by default. For
configuration information for this feature, refer to the switch software
configuration guide or the switch command reference"
I copied and pasted this from a posting from another site! HTH
This is only available on the newer switches and routers , the older stuff like 2950,3550's do not support this.
thanks for this
