Call Manager +Unity Express AA from PSTN Fail
Sep 23rd, 2008
I applied this config (see the file attached) on the router but autoattendant from pstn does not work. is the unity express ip address and autoattendant access number is 700.PSTN is 021314876.
kolawole1 Tue, 09/23/2008 - 06:39
Iam using call manager 4.1 and auto attendant is functionning internally but not from pstn.
slongewa Tue, 09/23/2008 - 07:48
What are you trying to accomplish by applying an outgoing translation_rule on the AA dial-peer? I would apply a translation rule to the inbound dial-peer of the POTS number for the AA's external number. Then in your dial-peer for the AA, you can just set the destination pattern to 700 and not have to worry about when the translation occurs and what it looks like when it hits your CUE module.
slongewa Tue, 09/23/2008 - 10:46
Sure. Hopefully this makes some more sense as to what I'm trying to say..
dial-peer voice 1 pots
Description Inbound FXO port
translate outgoing called 5
! 5 is the rule that does your /XXXXX/ /700/ translation
incoming called-number .%
port 0/1/0
dial-peer voice 700 voip
Description AA Dial Peer
destination-pattern 700
session target ipv4: ! Your IP Address
session protocol sipv2
codec g711ulaw
no vad
dtmf-relay sip-notify
kolawole1 Tue, 09/23/2008 - 23:31
Hi iam using an mgcp gateway do you think the voice translation rule will work?
slongewa Wed, 09/24/2008 - 05:15
I'm sorry! I didn't realize you were using an MGCP gateway. What version of Call Manager are you using? We can do an MGCP style translation there if you'd like.
