ADvice on TACACS+
Sep 23rd, 2008
Hi there
I am trying to implement the following scenario and would like to know the best solution for me,
We have 2 groups of Remote VPN users 1) support 2)Operations both using Cisco client vpn to log in remotely to our site
1)When members of the support group VPN in, I want our Cisco ASA to give them an IP range from Pool A of Ip addresses and I want them to be authenticated using TACACS and then after successful authentication they are redirected to or only have access to Server A
2)When members of the Operations group VPN in, I want our Cisco ASA to give them an IP range from Pool B of Ip addresses I want them to be authenticated using TACACS and then after successful authentication they are redirected to Server A AND have full access to Servers B,C,D etc
Is this possible? and if so how?
Collin Clark Wed, 09/24/2008 - 08:06
Yes that's possible. Restriction to devices is done on the VPN device itself, not through AAA. Create two different VPN groups; one for support and one for Operations, each can authenticate to AAA.
Hope that helps.
