SIP Trunk definition
I was reading in the SRND guide that if you have a SIP trunk defined in callmanager, the way you get CM redundency is thru dial-peers so you point the first dial peer to the primary callmanager and a second dial peer to the backup callmanager.( page 4-17 of the 01/08 CM6)
This is the first I seen this and this is not the way we have done our deployments.
The config we have is cm 5.1.3, IPCC enterprise 7.X and CVP ver 4.1. SIP is the preferred way for connections.
As anyone setup their dial-peers like I mentioned in the SRND guide.. page 4-17 of the 01/08 CM6
I asked some of our local guys and this is new to them ...
Any thiughts or ?
Brandon Buffin Tue, 09/23/2008 - 04:48
Mike,
Yes, this is a best practice. So, for incoming calls, you could have something like:
dial-peer voice 1 voip
destination-pattern 1112223333
session target ipv4:1.1.1.1
dial-peer voice 2 voip
preference 1
session target ipv4:2.2.2.2
If the CM at 1.1.1.1 happened to be down, incoming calls would be handled by the CM at 2.2.2.2.
Hope this helps.
Brandon
