incorrect CRC received on packet
Answered Question
Sep 23rd, 2008
i got this message "incorrect CRC received on packet" when connecting router through putty.kindly suggest any solution ....
Correct Answer by Calin Chiorean about 8 years 8 months ago
Hi!
This error occurs when PuTTY decrypts an SSH packet and its checksum is not correct. This probably means something has gone wrong in the encryption or decryption process. It's difficult to tell from this error message whether the problem is in the client or in the server.
Try with different settings on Putty, disable/enable SSH on router and maybe it will work.
Under Putty check SSH settings. This error happens usually with SSH 1 + Blowfish encryption.
Good luck!
Calin
Overall Rating: 5 (1 ratings)
Correct Answer
Calin Chiorean Tue, 09/23/2008 - 05:36
  • Silver, 250 points or more
Hi!
Good luck!
Calin
