WS-C2948G-GE-TX <--Etherchannel--> 3560G-24TS
Sep 23rd, 2008
Hi All,
Someone please clarify if we can etherchannel between WS-C2948G-GE-TX (cat OS) and 3560G-24TS (IOS). It sounds like 'YES' but just want to get openion from gurus..:-)
Thank you in advance
Overall Rating: 5 (1 ratings)
glen.grant Tue, 09/23/2008 - 06:48
Yes you can etherchannel between the two .
set port channel slot/port desirable non-silent
on the interface
channel-group X mode desirable non-silent
mvsheik123 Fri, 10/03/2008 - 20:25
Thank you for your reply and apologies for the delay in getting back. So I used the link
and current config...(using 2/1 & 2/2 for port-channel)
set port channel 2/1-2 10
set trunk 2/1 nonegotiate dot1q
set trunk 2/2 nonegotiate dot1q
(by default it allows all Vlans).
The port 2/1 & 2/2 were initially set for Vlan771 than 1(that we created). I have not made any connections to other switch, but the o/p:
sh trunk:
Test-2948-S1> (enable) sh trunk
No ports trunking.
TEST-2948-S1> (enable) sh port channel
Port Status Channel Mode admin Group
2/1 notconnect on 10 417
2/2 notconnect on 10 417
Sh port 2/1
Port Name Status Vlan Duplex Speed
2/1 Test notconnect 771 auto auto
Same with 2/2 also (not showing Trunking)
Do I need to move the ports 2/1 & 2/2 to Vla1 before enable trunking..? or the Trunk pops up when I connect the other switch ports?
Thank you
Edison Ortiz Fri, 10/03/2008 - 21:09
The trunk will form once the ports become up/up after being connected to another switch.
mvsheik123 Sat, 10/04/2008 - 10:52
So the Switch ports (2/1 & 2/2) currently showing being members of VLA771 at this time does not matter. Thank you for the reply Edison. Will post how it goes.
Thank you
Edison Ortiz Sat, 10/04/2008 - 17:23
When the switch isn't connected and it's configured as trunked, it will list being a member of its native Vlan.
