Failover
Sep 23rd, 2008
I have two PIX 525 running version 8.03 with failover. One of the PIX license is Active/Active, and the other is Active/Standby (FO) license.
One hour ago, the PIX just failover. Currently the secondary PIX (Active/standby) is active, what will happen if this PIX had a problem, will it failover over back to the Primary (Active/Active) itself? or I should manually failover it back to the Primary now instead of waiting?
suschoud Tue, 09/23/2008 - 09:36
  • Gold, 750 points or more
YES
NOT NECESSARY.BUT IF YOU ARE LIKE MANY PPL OUT THERE WHO LIKE TO SEE PRIMARY AS ACTIVE ALWAYS...YOU CAN ISSUE " FAILOVER ACTIVE " COMMAND ON THE PRIMARY/STANDBY UNIT.This would make it active.
Sushil
