Cat OS-TACACS plus
Sep 23rd, 2008
we have new switches using Cat OS TACACS plus, I have a script manipulating information from different switches, the one using using IOS TACACS no problem. unfortunately my script unable to log to the switches using CatOS TACACS plus. keep rejected. any body experiences the same problem and got any solution. or at least what's main difference between the two TACACS and what what I should look to write new scripts. thanks
Harold Ritter Tue, 09/23/2008 - 08:18
Elias,
I would recommend you post this question on the NMS Forum (under Network Infrastructure).
