Log Agents Out Automatically
Sep 23rd, 2008
I'm running IPCC Express 4.05 and would like to be able to log all agents out at a certain time 6pm. A lot of times the agents stay logged in, and calls do not roll to my answering service. Is there a way to force this to happen in my script?
bobsairam Tue, 09/23/2008 - 09:13
  • Bronze, 100 points or more
Hi.
The best logs for troubleshooting
these types of issues are the MCVD, MIVR, and Event Viewer logs. Can
upload the following logs from the CRS server that was primary
during the time of the failure? The logs containing the 5:30pm - 6:30pm
time frame will be most relevant.
C:\Program Files\wfavvid\log\MIVR
C:\Program Files\wfavvid\log\MCVD
Windows Event Viewer - System (saved in .evt format)
Windows Event Viewer - Application (saved in .evt format)
Are you using IP Phone agent or CAD ?
alan-white Tue, 09/23/2008 - 10:29
There are not any failures. What I want to happen is at 6pm, all agents (CAD) get logged out of the system automatically.
jpsweeney77 Wed, 10/29/2008 - 21:29
I'm assuming you do not want to use Time of Day logic in your scripts? As far as logging out agents automatically, there is no built in functionality that will facilitate this. There are some third party tools that I've seeen that will do this.
