WAAS CM slowdown - 4.1.1
Sep 23rd, 2008
Has anyone else noticed the GUI to their CM in 4.1.1 slow down. It now takes me several minutes to load or refresh a page, which used to take several seconds.
I'm running 4.1.1, the CM manages about 110 remote WAEs (with no problems under prior releases), my CM is a WAE 512.
Zach Seils Tue, 09/23/2008 - 20:03
Are you local to the CM? What is the CM CPU utilization. If you can send me a system report from the CM, I'll take a look at it.
richianaj Wed, 09/24/2008 - 05:38
Yes the CM is on my local network. What is the command to generate a system report.
