Personal Directory on CM 6.1
Sep 23rd, 2008
  • Bronze, 100 points or more
Does anyone know where or if there is a timer/ parameter that logs you out of personal directory automatically .I want to make sure that once the users login it never logs them out again.
thanks
mark
Overall Rating: 5 (2 ratings)
Jaime Valencia Tue, 09/23/2008 - 09:50
  • Cisco Employee,
  • Hall of Fame,
    2011
no parameter, look at this:
CSCsd91156
CM5.0 - Personal Directory Enhancements.
Symptom:
CM5.0 Personal DIrectory login from the phone has a timeout value of 30 mins
and the users have to login again after the timeout.
Please add user-defined timeout and zero timeout capability
Workaround:
Users must login using Userid/PIN until this feature is integrated
In the CUCM Versions listed in the Bug Id CSCsd91156 "Log Out" feature has been added in the personal address book which will prevent the auto log out and a user will always remain logged in until a users hits the "Log Out" option.
java
if this helps, please rate
rraver Tue, 09/23/2008 - 14:04
Is there a way for auto-login, we had this working in 6.0.1 but when we upgraded to 6.1.2 it broke the URL and auto-login feature. The current configuration is:
URL: http://:8080/ccmpd/pdCheckLogin.do?
Parameters
name
pin
userid
It brings the to the login screen with username/pin and nothing prepopulated. Kind of like it never passed any info.
mknepper Tue, 07/21/2009 - 14:34
Ever get this figured out? Need it now for ver 7.1?
