CiscoWorks Startup/Running Out Of Sync Issue
Sep 23rd, 2008
We use Ciscoworks Startup/Running Out Of Sync to check if we have missed to issue wr mem after change on any device.Strangely we find Cisco routers ,the one with Crypto IOS ,Out Of Sync even after a wr mem.The Difference in 2 config files is of the crypto signatures (which is a long string of characters viewable)which does not synchronise with the startup config.Grateful if one can help solve this issue.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 09/23/2008 - 14:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is a known issue (see CSCec68083). You must be running LMS 2.5 or higher, telnet or SSH must be your primary config fetch protocol, and your IOS must support the "show running-config brief" command. This way, we can issue the "show running-config brief" command which will omit the crypto map details. If TFTP is the primary fetch command, then you will see the out-of-sync problem.
rohan.jhaveri Tue, 09/23/2008 - 21:28
Following is the version details
SSL Compliance Info
Name Version Install Date SSL Compliant
CiscoWorks Common Services with SP2 2.2 Feb 9 2007 01:19 YES
Resource Manager Essentials 3.5 Feb 20 2007 22:27 YES
Resource Manager Essentials Incremental Device Support 3.5 Feb 20 2007 22:27 YES
Campus Manager with Update 1 3.3 Feb 26 2007 19:06 YES
Device Fault Manager 1.2 Feb 20 2007 20:19 NO
Device Fault Manager Incremental Device Update 1.2 Feb 26 2007 18:53 NO
Yes we manage config changes via Telnet.I verified that sh runn brief omits the crypto details.But how can I tune Ciscoworks to poll using sh runn brief,can you advise.
Joe Clarke Tue, 09/23/2008 - 21:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Your version, LMS 2.2 is now end of support. You should upgrade to LMS 2.6 or 3.1. You will not be able to get the fix otherwise.
