ASA access list's logging
Sep 23rd, 2008
I have ASA firewalls from which I need logs collected from few ACL rules.
logging enable
logging timestamp
logging console errors
logging buffered notifications
logging trap informational
logging asdm informational
logging facility 22
logging host inside 10.1.23.22
access-list access_out extended permit ip any any log debugging interval 300
I have this logging configuration and the a access rule to log all connections. But I dont get any logs from this access list rule or this access list. The only log I get is Built/Teardown log and some system notifications.
What is missing here, I want to get "access-list" log for connections hitting this ACL rule.
Thanks..
dominic.caron Wed, 09/24/2008 - 05:04
In your ACL, you set the log level to debugging...
Your ASA is not configure to log any message of that level. Let's say you want to send the log in the buffer, you would need to configure:
logging buffered debugging
innetsecwork Wed, 09/24/2008 - 06:30
Thanks for the reply.
The ACL is set to debug level, and I am looking for logs to come on the syslog server, not just in the buffer.
So I am not sure what else I need to add in it.
Thanks...
suschoud Wed, 09/24/2008 - 11:10
Put in :
logg trap 7
Should work then.
Do rate helpful posts.
Sushil
cisco24x7 Wed, 09/24/2008 - 11:35
Why do you need "logging trap 7"? I thought
"logging trap 6" will send ACL log to the syslog
server.
I have a couple of Pix firewalls that send
ACL logs to Linux syslog server with "logging
trap 6" in the configuration.
