Stop process pak for forus packet
Sep 23rd, 2008
My interface has IP and I ping a device on the same subnet with IP and I get with debug on the response Stop process pak for forus packet. Any idea what is happening?
Giuseppe Larosa Tue, 09/23/2008 - 11:58
Hello Carlos,
it could be normal behaviuor it should simply say that the return packet is process switched = sent to main cpu.
I remember another thread where the same sentence in the debug ip packet was shown in the process of translating a DHCP request for the ip helper-address command.
So if the ping is successful (you are getting responses) everything should be fine
Hope to help
ciceseredes Tue, 09/23/2008 - 12:43
Hello Giuseppe,
Yes, I am getting responses. The real problem is that my switch has another interface, e.g., and I try to ping from my MacBook and I never get responses...
Giuseppe Larosa Tue, 09/23/2008 - 13:00
Hello Carlos,
try to use debug ip icmp on the switch and from the MAC try to ping
before doing that :
verify that and are in the same IP subnet;
that is the GW for the
if you have ACL on L3 interfaces or you are doing NAT this can change the ping results:
what if from switch you do an extended ping to with source ?
Hope to help
