Unaddressed messages
Answered Question
Sep 23rd, 2008
we have a customer where for legal purposes cannot allow another subscriber access to someone elses VM - therefore we cannot add subscriber to unaddressed messages. We have changed the default CH so that the after message option is not to take a message but to hangup. Also can we set the eadmin account to have its messages deleted straightaway using message store monitor. Any other suggestions how we can avoid eadmin and the unaddressed messages filling up with messages, can we delete all messages from unaddressed messages?..cheers, Jag
Correct Answer by Bradford Magnani about 8 years 9 months ago
Jag,
No, the distribution list will not fill up if there are no recipients listed, even if EAdmin is the owner of the PDL. I just set it up in the lab and tested when EAdmin was a member of the unaddressedmessages PDL, and the message arrived in the mailbox. I removed it from the PDL and no message was delivered.
Check out the following link for how messages get sent to the unaddressedmessages PDL
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/administration/guide/dom/SAG_0180.html
Hope this helps,
Brad
Overall Rating: 3.8 (5 ratings)
Bradford Magnani Tue, 09/23/2008 - 12:38
  • Cisco Employee,
Jaginder,
Yes, you can configure the MSM (Message Store Manager) tool in the Tools Depot to "Move Messages From Inbox to Deleted Items Folder" for the EAdmin account. If you don't want EAdmin to receive these messages at all, you can remove it from the unaddressedmessages distribution list so that there are no recipients.
Hope this helps,
Brad
askq2forum Wed, 09/24/2008 - 02:59
Brad, thank you so much for your reply. if I remove eadmin from unaddressed messages that will mean unaddresses messages DL will just fill up - is that correct ? Can we delete the messages from this DL?....cheers Jag.
Correct Answer
Bradford Magnani Wed, 09/24/2008 - 07:01
  • Cisco Employee,
Jag,
Hope this helps,
Brad
ranpierce Wed, 09/24/2008 - 07:33
  • Silver, 250 points or more
You should and need to have a member of the unaddressedmessages dl. for other reasons. Eadmin can be taken out and add your Unity admin
The main reason is if there is a vm that comes in to that dl, the admin will get it and can forward it to the right subscriber.
It would not be a good idea and not good for business just to delete all those vm.
I would again reccomend taking eadmin out and putting your Unity admin in or another appropriate admin in. You can have more than one also.
Randy
askq2forum Wed, 09/24/2008 - 12:57
Randy, totally agree with you and all our installs do include someone in the DL to distribute the messages - however this customer has a legal requirement that only the receipient of the VM can receive it and no one else.
ranpierce Wed, 09/24/2008 - 13:06
Voice Mail Jail..........:-)
My lab is down right now or I would test this for you. I can not test this is production.
I will try to find out. Interesting question.
Randy
Bradford Magnani Wed, 09/24/2008 - 13:10
  • Cisco Employee,
I tested this, and I didn't see the message in UnityMTA or Failed folder... very good question.
ranpierce Wed, 09/24/2008 - 13:48
I am going to do some Exchange traces in the morning. My guess is exchange is handling it.
Randy
askq2forum Mon, 09/29/2008 - 06:03
Brad, any further info on this?...cheers, Jaginder
Bradford Magnani Mon, 09/29/2008 - 07:36
  • Cisco Employee,
Randy was going to do some testing according to his last post. I haven't had time to do any testing myself.
ranpierce Mon, 09/29/2008 - 14:02
Sorry I didn't forget just have to get permissision to test in production after hours. It is not going to hurt anything. I will let you all know what I find out.
Randy
ranpierce Wed, 10/01/2008 - 11:41
I tested with an emty dl in exchange. and by sending an email to it the email address is valid so I did not get an NDR but no one recieves the email.
The same would happen to vm if it was addressed to a dl with no recipieints I am pretty sure.
Randy
askq2forum Thu, 10/02/2008 - 04:06
Thanks Randy much appreciated - so this shows that the messages will just get stacked up in the DL with no one actioning them...is that right?
ranpierce Thu, 10/02/2008 - 14:23
I am pretty sure they dissapear as there is now where for them to go. DL do not have mailboxes. Only mailboxes assigned to them. Since you do not have a user assigned then there is now place to deliver the message.
Randy (if I am wrong please ring in)
Hope this helps.
