How can i clear the call log information op Cisco7940/7960 automaticly?
Sep 23rd, 2008
I'am looking for a solution to clear the call log information on the IP Phone 7940/7960 automaticly when a user logged off the phone.
The call log information is saved on the phone and can only cleared by pressing the clear button if jou activate the directory button! I need a solution in case of privacy, because other users can see the call history of the last user!
In our office we use extension mobility!
So is there a solution for my problem?
Rob Huffman Wed, 09/24/2008 - 04:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Roelof,
This funtionality is not built-in to any Communications manager version at this time but is available in the latest CME release 4.3/7.0 so I wouldn't be surprised to see it in the soon to be released CCM 7.0 (Q3 2008)
There have been some threads related to this question with a workaround resolution provided by NetPro Aaron;
From Aaron;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde2846/1#selected_message
Extension Mobility Enhancement Cisco Unified CME 7.0/4.3
Adds support for the following:
•Automatic Logout, including:
-Configurable time-of-day timers for automatically logging out all Extension Mobility users.
-Configurable idle-duration timer for logging out an individual user from an idle Extension Mobility phone.
•***Automatic Clear Call History when a user logs out from Extension Mobility.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
Hope this helps!
Rob
D0nprintup_2 Wed, 09/24/2008 - 10:43
On our call manager we have the following
Under -- Device -- Phone -- (On the main phone page) Cisco IP Phone - External Data Locations. We have in the Idle section http://(IP ADDESS OF THE SERVER)/CCMCIP/clearcallhistory.xml
This XML file was included on our Publisher in the c:\CiscoWebs\IPPhoneServices\CCMCIP DIR
I beleive all Publishers have this installed (I worked with 4 so far and they all had it).
I would check and make sure yours is there. See if the HTTP server is working too. Just http://(IP OF PUB)/CCMCIP/clearcallhistory.xml
From a brower and see if you get the XML. If you do place that path in the idle section. Also check the Idle timer to something like 1 or 2 secsonds. Otherwise it will wait for that idle timer to expire before it runs.
RoelofB Wed, 09/24/2008 - 10:48
Hello Aaron and Rob
Thank you very much for this information! It will me help in the right way. There is only one problem: I can't download the clearcallhist.xml file. Is it possible that you send it by email?
With kindly regards,
Roelof Bakker from Holland
D0nprintup_2 Wed, 09/24/2008 - 10:49
it is not already on your pub or sub?
Paste this into notepad and then save it as a XML file ------
RoelofB Thu, 09/25/2008 - 13:19
Aaron and Rob,
I've test your advise with the xml file and it works. I did some experiments with the idle timer so you can regulate the time the call history exist!
The only problem now is, that we must configure all the phones, where we need this solution (more than 5000 phones)
Once again thank you very much for this solution.
Roelof Bakker
D0nprintup_2 Thu, 09/25/2008 - 17:54
You can use the BAT tool to update all your IP phones.
ITs under applications/BAT in our version (4.1)
will.alvord Fri, 09/26/2008 - 08:12
  • Silver, 250 points or more
If you're making the change to EVERY phone on that cluster, you can just put the idle url and timer settings in enterprise parameters.
cheers,
Will
Afragoso2009 Mon, 03/16/2009 - 10:06
Hi Roelo
What kind off feature are you using to have user able to log on and log off the phone ?
Can You please tel me the details?
lwai Wed, 03/18/2009 - 20:55
Does anyone use this method in CM version 5.x or 6.X?
Can we put it in CM 5.x or 6.x to clear call history in ip phone sets??
Thanks!
Michael.
RoelofB Thu, 03/19/2009 - 00:26
Hi Michael,
I don't know, because we are using CM version 4.1
Kindly regards,
Roelof Bakker (The Netherlands)
RoelofB Thu, 03/19/2009 - 00:21
Hi Afragoso2009,
We use the extension mobility function of the Cisco Callmanger to give users the posibility to logon and logoff on a phone. So you can use your own phonenumber everywhere in the office or in the network. Every user got a user account en user profile which is related to the useraccount. Every user can manage his own user profile with a webbased tool.
I hope that this answer is enough for you?
Kindly regards,
