Problem to create a one User
wilsonsant
Level 6
Level 6
Hi Guys,
I trying to create a new user in the Cisco CallManager version 4.2 and is appear the message:
"The following error occured while trying to load the requested page. Problem is executing fso.OpenTextFile()"
That can be occuring? Where is the problem?
Thank You,
Wilson Santana
7 Replies 7
Jaime Valencia
DCD or AD integrated?
if DCD restart the DCD service, if AD rerun the directory plugin
java
if this helps, please rate
java
Hi Javalenc,
Where I can see what my Customer is using?
Thank You,
Wilson Santana
did u upgraded from any lower version?
and check your disk space where CCM installed
javalenc,
Explain to me what is DCD and AD, because I have the same problem...
ps.: Is AD active directory?
DCD = DC directory
AD = Active directory
java
java
Hi Javalenc,
My co-worker Danilo found the bug: CSCeg64265 Bug Details
ERROR: Problem in executing fso.OpenTextFile().
Description
When the regional setting (in windows) is not set to US English, customers running CM release 3.3 might get the following error
when trying to access the global directory :
"The following error occurred while trying to load the requested page.Problem in executing fso.OpenTextFile() ". But, there is not workaound to do or fixed. Is this can be the problem?
Thank You,
Wilson
i don't know, do you meet the conditions of the bug and the version??? you're the one that could tell if it could be it or not
java
java
